on 06-06-2024 11:52 AM
I've been experiencing issues connecting my WIFI speakers to the Router (SONOS & Echo)
Could we please try dissabling "WIFI optimization"
Many thnaks
Martyn
on 28-06-2024 10:39 AM
Hi @MattBS
That's great, thanks for letting us know.
It was @martynwjones who came up with this solution 🙂
on 28-06-2024 10:34 AM
hello again Sophie, I tried this again on my old iPhone and although it is not the latest iOS (16 or later recommended for the Sonos S2 app), it works! So, thank you. I have a working solution. Great.
Matthew
on 28-06-2024 07:30 AM
Hi @MattBS
Ok thanks for confirming.
Please can you create a new topic here Broadband - TalkTalk Help & Support
We can then take a look at this for you.
on 28-06-2024 07:23 AM
hi Sophie, yes I tried this. The Sonos wifi setting is on by default. I've toggled it off then on again. I tried this with the app open and also with it closed. I've also restarted the phone with it toggled off and then turn it on and started the app. None of these seem to fix the issue.
on 27-06-2024 09:25 AM
Hi @MattBS
Have you tried this fix?
On my iPhone
via iPhone settings >Sonos App> toggle ‘local network’ to [on].
It seems on initial setup the SONOS app ignores this setting. Then when you close the app and re-open it reads the local network is "off" and will not allow connection to the speakers.
on 27-06-2024 09:24 AM
Yes, that is all it was 🙂
on 27-06-2024 09:23 AM
I'm so glad to hear this 🙂
Was this still the fix?
On my iPhone
on 27-06-2024 09:20 AM
All good now thank you !
on 27-06-2024 09:18 AM
Hi @MattBS
Please can you create your own topic on the Community, we can then take a look at this for you.
on 27-06-2024 09:13 AM
I'm now also having problems getting my Sonos Roam to connect to the TalkTalk router. At first I thought it was my old iPhone which has iOS 15 but I've tried with a later phone that is iOS 17.5.1
The TalkTalk router does not allow the Roam speaker to update via the Sonos S2 app. I've tried a firmware reset to the speaker, removed & reinstalled the app, rebooted the router. The speaker has an IP address and appears in the WiFi 2.4GHz connected devices, but does not work correctly.
Is there a solution available please?
on 11-06-2024 08:42 AM
How's the connection been since your last post?
on 06-06-2024 01:27 PM
Thanks again ferguson 🙂
I know Arne (on my team) did have some issues recently. I will ask him to check his settings too.
on 06-06-2024 01:26 PM
Always stays that way, never had any disconnection issues.
on 06-06-2024 01:24 PM
on 06-06-2024 01:20 PM
This is what mine looks like, can't remember what I did on setting it up tbh.
on 06-06-2024 12:46 PM
Thanks for your reply 🙂
Will it allow you to change it to always on?
My colleague Arne uses a Sonos, I can ask him to check what his shows.
on 06-06-2024 12:44 PM
Thanks. I am making progress... 🙂
I think I found the issue, but it is very strange how it occured.
On my iPhone
The blame is deffo with SONOS - or could be the iphone 🙂
Thank you Talk talk again for your fast response!
on 06-06-2024 12:26 PM
Hi martynwjones
Thanks for confirming. I've asked our Devices Team to have a look at this and I will post back as soon as I have further information.
on 06-06-2024 12:19 PM
Yes - I have witnessed both the speakers and the app updating in the last few days
on 06-06-2024 12:18 PM
Hi martynwjones
Can I just check, has the Sonos and app got the latest software updates installed?
