on 20-02-2024 07:16 PM
Hi there,
I work from home and needed to contact my IT Dept to add some software to my work laptop. The IT Team uses Logmein123 but the site was unable to connect, instead getting an error message:
secure.logmeinrescue.com sent an invalid response.
This error message happens over my home network, which is TalkTalk, but not when connect the laptop to a mobile hotspot which uses EE. This suggests the issue is on the home network.
Is there a fix for this?
Thanks!
on 10-02-2025 11:16 PM
@Oldnagger1, this is another customer's old thread. You need to start your own.
Support staff only reply to the original poster. Please return to the message board and click on start a topic to begin your own thread.
on 10-02-2025 10:57 PM
I have this problem even when I connect through a hotspot rather than Talktalk broadband. Will removing scam protection in my Talktalk profile resolve the problem?
on 20-02-2024 10:08 PM
Have you disabled Scam Protection which is part of HomeSafe. The Homesafe settings can now be managed yourself, from within MyAccount, please follow the below steps to disable scam protection on your line:-
1. Log into MyAccount
2. Select My Services
3. Select View HomeSafe settings
4. Go to the Scam Protection section
5. Select OFF and confirm when you see the pop up window
