Does TalkTalk block websites like www.reddit.com?
Martin84
Whizz Kid
Message 28 of 28
I find that whenever I use my TalkTalk account to try to access www.reddit.com, that I am presented with the message:
This site can’t be reached
The connection was reset.
Try:
ERR_CONNECTION_RESET
Is TalkTalk blocking www.reddit.com at all? I do not believe that I use the various HomeSafe or other security tools TalkTalk provides. I am also connecting directly to TalkTalk via a router supplied by them, and am not using any proxy or VPN.
This problem occurs regardless of the browser I use.
27 REPLIES 27
Billx
Message 1 of 28
 https://www.reddit.com/r/london defaults to https://www.reddit.com
 https://np.reddit.com/r/london/ goes to exactly https://np.reddit.com/r/london/
So, yes, they seem to be different domains
and my system goes to either, with no issue.
Message 2 of 28
Thank you for letting us know @Martin84 :).
Martin84
Whizz Kid
Message 3 of 28
Thanks to the respondents but this issue has now been identified.
I had thought that this might have been a case of TalkTalk blocking https://www.reddit.com/r/london
Rather, I have found out that it is necessary for me to use addresses like https://np.reddit.com/r/london/
So, perhaps others will find this post useful.
Message 4 of 28
We will get back to you once we have feedback
Message 5 of 28
I have escalated this for you, please bear with us as we look into it, thanks.
Message 6 of 28
@amahle-TT Does this seem like an issue with TalkTalk or something else entirely?
I have checked Windows Firewall settings and sundry other applications. But the problem affects all browsers on the two PCs I use to connect to TalkTalk. The router settings do not indicate anything being wrong either.
Of the websites I use normally, it is only https://www.reddit.com that seems to be affected in this way. Hence, my query about TalkTalk blocking websites.
Message 7 of 28
Message 8 of 28
Thank you for confirming.
Message 9 of 28
@amahle-TT I could access https://www.reddit.com without any problems at all.
Message 10 of 28
you were able to open the site before?
Message 11 of 28
@amahle-TT This must have started about three weeks ago.
Message 12 of 28
Please confirm when did you start experiencing this issue, is it the first time happening ?
Message 13 of 28
Thank you, bear with me as we are looking into this for you.
Message 14 of 28
@amahle-TT An interesting idea concerning AdBlock. But switching it off does not change anything.
Message 15 of 28
Please confirm if you have Ad Blocker on.
Message 16 of 28
@amahle-TT The message I see is described in the first post I made to this thread. I see nothing that explicitly states that https://www.reddit.com is being blocked.
Message 17 of 28
Thank you, do you see a blocked webpage notification message when attempting to access the site you experience problems with?
Message 18 of 28
@amahle-TT No. I have nothing of this nature.
Message 19 of 28
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
Message 20 of 28
@amahle-TT Yes. I am currently at home.
