Sagecom FAST5364 WAN to Ethernet Conversion?
threefins
Message 3 of 3
Dear Community
I’m hoping to free up another Ethernet port on the router. Is it possible to configure the WAN to work for Ethernet? I’m on Fibre65 so no Fibre connection required at the router😊
Message 1 of 3
Thanks @KeithFrench , you've saved me from wasting a lot of time and effort. I'll go ahead and look at the switch option.
Message 2 of 3
No, if you want extra LAN ports then you will have to buy a gigabit switch for this. You can normally pick them up cheaply on the Internet.
