on 06-11-2023 02:49 PM
I am experiencing the same faults I had around 6 months ago. My connection drops out around 6 or 7 times a day and over the past 2 weeks the speed has been fluctuating and is now down to 27mbps. When checked on your website it states the status as poor. I have carried out all the checks you ask to be done as I did on previous occasions
Monday
Good morning,
Thanks for keeping us updated. If the speeds does start varying again then please let us know.
Monday
Over the past week my download has been around 33Mbps, There has been no dropping out , the router seems to have made a difference . On Saturday the speed became very erratic ,sometimes dropping to low 20’s, it was up and down all day . Sunday it was steady again. Today so far it’s steady at around 31Mbps. I’m quite happy as long as it stays at a steady speed although it’s still slower than it was 7 months ago which was between 35-40 Mbps..
Thanks again for all your help, it’s much appreciated
Dodge08
on 23-11-2023 01:36 PM
How are you getting on?
Michelle 🙂
on 20-11-2023 01:32 PM
Good afternoon,
I'm glad to hear this and we'll check back in with you towards the end of the week to see how you're getting on 🙂
on 20-11-2023 01:30 PM
Hi Debbie
Got the router up and running on Saturday , since then it hasn’t lost connection at all. The speed at first was a bit erratic but it seems to have settled down now at around 32 Mbps. A most noticeable thing was the improvement of the wifi reception around the house. I’ll keep monitoring it over the week as I’m not confident enough yet to say it’s a complete fix , but it’s looking good . Thanks again for all your help
Dodge08
on 20-11-2023 06:30 AM
Hi Dodge08
How's the connection been over the weekend?
on 17-11-2023 12:59 PM
Afternoon,
Ok thank you for the update and we'll check back in with you on Monday morning to see how you're getting on.
on 17-11-2023 12:56 PM
My son is coming tomorrow to connect and set up the router for me. Unfortunately since the engineer visited and the speed improved its progressively got worse again , connection dropping out frequently and speed getting lower. I’ll see how it performs over the weekend with the replacement router and let you know
Dodge08
on 16-11-2023 07:43 AM
on 14-11-2023 07:04 AM
Hi Dodge08
on 10-11-2023 01:18 PM
Hi Dodge08
I have ordered the replacement router for you, please allow 24-48hrs for this to arrive.
Please let us know how the connection compares with this router.
on 10-11-2023 01:07 PM
Hi Debbie
The engineer came this morning as arranged. He has fixed the fault which was a corroded connection underground. Speed improved immediately, he checked the speed into and out of the router . He said there’s a slight leakage of signal in the router and suggested I ask for a new up to date router which would improve the signal even more . If a replacement is possible I would be grateful. Thanks for all your help.
Dodge
on 08-11-2023 01:08 PM
Hi Dodge08
Thank you 🙂
on 08-11-2023 01:07 PM
Hi Debbie
Thanks for that , I will let you know
Dodge
on 08-11-2023 12:46 PM
Hi Dodge08
Thanks for confirming your details.
I have arranged the engineer visit for 10/11 AM (8am - 1pm)
Thanks again.
on 07-11-2023 10:17 AM
Hi Dodge08
I'm just sending you a Private Message to confirm some details so we can arrange the engineer visit.
on 07-11-2023 10:15 AM
Hi Debbie
yes I’ve been through all the tests as on previous occasions . The line connection speed to the router is unstable it has been fluctuating for a couple of weeks , this morning it’s been between 29 - 33 Mbps and the current speed test on your website is reading 27 Mbps download and 4 Mbps upload and states Status Poor. I think an engineers visit is needed if you could arrange it please .
on 07-11-2023 07:01 AM
Hi Dodge08
The line test is clear - No faults detected, but I can see re connections on the line.
Just to confirm, have you tested with a different router at the test socket? The next step following this will be an engineer visit to the property.
