TR-069 connectivity to (acs.talktalk.co.uk) has failed
WaRRioR1976
Whizz Kid
Message 6 of 6
Hi. There was a brief power cut sometime around 6:00am today (I think it was about that time, but I was getting much needed beauty sleep - I need a lot of it!), and since then there's a lot of Tr-069 connectivity to (acs.talktalk.co.uk) has failed entries on the router logs.
I've got a Sagemcom Fast 5364 router running software version SG4K100174.
Do I need to activate Tr-069 connectivity manually, and, if so, how can I do this, please?
Thank you.
I'm a drummer in a very well known band, I'm also a world class racing driver and crazy golf world champion 7 years in a row. Please note - I'm a bit of a dreamer and try and make my life sound more interesting than it is, so the above statement might not be true.
5 REPLIES 5
Message 1 of 6
Hi WaRRioR1976
Oh I'm so glad to hear this 🙂
Thanks for letting me know.
WaRRioR1976
Whizz Kid
Message 2 of 6
Hi Debbie. No, I don't need a new router. I've just checked the router logs again and Tr-069 connectivity has been initiated, so it's all good now. Thank you for your help. 🙂
Message 3 of 6
Hi WaRRioR1976
Would you like me to send a replacement router?
WaRRioR1976
Whizz Kid
Message 4 of 6
Hi Debbie.
I've done a factory reset and the last entry in the router logs just three minutes ago said Tr-069 connectivity has failed...
Message 5 of 6
Hi WaRRioR1976
Have you factory reset the router using the pin hole reset? This will reset the router back to default settings.
