Throttling back Work VPN Connection?
Squidge87
Message 20 of 20
I have an issue whereby I am being throttled back on my Work VPN connection, I work in IT (for the same company) and there are no issues our side. My fibre connection is stable at 65/70mbps but the VPN connection fluctuating between 0.5mbps - 20mbps
I do not get throttled back on my Work VPN connection if I hotspot from my mobile to the laptop.
My router has been restarted several times aswell as laptop.
19 REPLIES 19
Message 1 of 20
Good morning,
How has your connection been over the weekend?
Message 2 of 20
Good morning,
Thanks for the update 🙂 We'll check back in with you early next week to just to ensure that your connection is still ok.
Message 3 of 20
Hi Chris,
All seems good now, whatever the network issue was TalkTalk end has now been resolved
Message 4 of 20
Hi Squidge87,
How are you getting on, are you still experiencing the same performance issues with your VPN?
Message 5 of 20
Hi Squidge87,
Could I just ask, if you are in touch with any of your colleagues who are TalkTalk customers and have the same issue it would be helpful if they could register on the community and post on the thread
Message 6 of 20
OK, leave it with me. I'll check with our network team and let you know when I have an update
Message 7 of 20
Hi Chris,
Nope no updates, as mentioned I can successfully hotspot from my mobile to the same laptop/vpn connection and is perfectly fine.
Another colleague has spoken with another TalkTalk support team member and they have advised its an issue with TalkTalk and NASSTAR
Message 8 of 20
And there was no update of any kind on the laptop or to the VPN?
Message 9 of 20
Hi Chris,
I have also swapped out routers to an older one (which has now caught up on firmware updates) and regardless of what network I connect to the Work VPN connection speed is drastically being throttled.
Speaking with our Service Desk a lot of TalkTalk users are experiencing the same issue and have been since late yesterday afternoon.
I can confirm we are using SSTP as the protocol for the VPN connection.
** I will mention that I work for the NHS and this is the VPN connection I am having
Message 10 of 20
OK thanks. Which OS is on the laptop and which VPN client are you using?
Message 11 of 20
Its not where it should be as its still throttling back, but doesn't seem to be going lower than the mid teens so is enough not to start freezing up RDP sessions.
Message 12 of 20
The router has the latest firmware version. Has the speed improved on the 2.4GHz band?
Message 13 of 20
I have now connected to the 2.4Ghz WiFi (was using 5Ghz, have separate SSID) and seems a little more stable for the Work VPN connection
Message 14 of 20
Hi Chris,
Connected via WiFi however shouldn't make any difference at all as the download speed I get from fast.com for example is 65/70mbps which is expected.
Please check the firmware versions, its unusable the Work VPN connection so I am having to resort to hotspotting from mobile.
Message 15 of 20
Thanks for trying that. I've checked the line history for Tuesday, everything looks fine, no interruption to service. The router firmware version that you have is unlikely to have only just been updated too. Is your laptop connected to your router by Ethernet cable or wifi?
Message 16 of 20
Hi Chris,
Router switched off for over half an hour and still the same.
Message 17 of 20
OK thanks, could you switch the router off and leave it off for at least 30 minutes, then switch back on and retest. Please let us know how you get on
Message 18 of 20
Hi Chris,
Yes it started late Tuesday afternoon, I have looked through the router logs and nothing jumping out (ignoring DNS issues with some work hosts that no longer exist but seemingly still exists within some group policies!)
Chris-TalkTalk
Message 19 of 20
Hi Squidge87,
Welcome to the Community, is this something that only started happening recently?
