on 24-01-2024 01:05 PM
Hello
How does one enable WiFi again after disabling it few years ago? There used to be a username and password online, but can’t find it now. Appreciate all the help.
on 24-01-2024 01:49 PM
OK thanks. You will need to log into the router's UI (user interface). The username and password are on the label on the back of the router under the pull out tab. You then need to go to wifi settings and there should be an option to enable wifi.
on 24-01-2024 01:38 PM
Thanks Chris, here it is:
router: Sagemcom-FAST5364
cheers!
on 24-01-2024 01:18 PM
Hi Saj7860,
What is the make and model number of your router?
