on 22-02-2024 06:03 PM
Apparently in order to connect a wifi printer we need to have the wifi frequencies separated to 2.4GHz and 5GHz and open a list of ports. TCP and UDP. No one seems to know how this is done. 3 hours of talking to robots and voice bots and a technician on chat between Hewlet Packard and Talktalk has achieved nothing and now we have no printer connection at all. Have these settings changed recently as the old wifi printer worked fine until fairly recently? We have bought a new printer because we thought the old printer was at fault. Can anyone help please? Do we need to change our internet provider in order to use a wifi printer?
on 08-03-2025 12:56 PM
While not the original enquirer I found this helpful and it allowed me to connect my printer, thanks.
on 26-02-2024 10:33 AM
Hi istewartkl
How are you getting on, do you still need help with this?
on 23-02-2024 06:53 AM
Hi istewartkl
Apologies for this.
You can split the SSID's to connect to certain devices. I've split mine to connect my printer and ring doorbell to 2.4ghz.
Split your router's SSID (wireless network name)
Your router automatically chooses a wireless frequency to broadcast on every time you connect to Wi-Fi. There are two frequencies to choose from:
5GHz frequency
This frequency encounters less interference from other devices, so it can handle much faster speeds, but your Wi-Fi coverage will probably not be as good. As the frequency is higher, it doesn’t penetrate solid objects nearly as well as the 2.4GHz frequency. 5GHz is the best frequency to use when you're close to your router.
2.4GHz frequency
This frequency can travel much further and penetrate solid objects more easily. However, traffic from other common household devices can limit your overall speed – microwaves, cordless phones, even your neighbour’s Wi-Fi. 2.4GHz is the best frequency to use if you're outside or in a different room to your router.
You can choose which frequency to connect your devices to by accessing your router's settings and changing the wireless network name (SSID) for each frequency. Choose your router from the options below to get started.
Which router do I have?
Your router's make and model is on the sticker on the back of your router. The make comes first (e.g. Huawei) followed by the model (e.g. HG633).
Wi-Fi Hub Black (Huawei)
Wi-Fi Hub (Sagemcom)
