6 hours ago
Getting very low speeds on 2.4Ghz whereas 5Ghz is running at expected speed of 450Mps
Also 2.4 Ghz connection keeps disappearing and need to reboot route.r Any ideas?
4 hours ago
Yes please. That would be great.
5 hours ago
Would you like us to send a replacement router for testing purposes to rule this out?
6 hours ago
This has only happened in the last week or so. Prior to that speeds on both wifi channels were fine
6 hours ago
Can I just check, has this only recently happened (the speed issue) in the last few days/week? Were the speeds ok prior to this on both wifi channels?
6 hours ago
yes.... a number of times.
I have also noticed that there are no system logs available anymore
6 hours ago
Thanks for confirming. Have you tried resetting the router and then setting it back up again?
6 hours ago
It is a Sagemcom FAST 5364
6 hours ago
Good afternoon,
Which router are you using please? (make and model)
