2.4Ghz speed is only 20Mps 5Ghz is 450Mps
jigsaw004
Message 28 of 28
Getting very low speeds on 2.4Ghz whereas 5Ghz is running at expected speed of 450Mps
Also 2.4 Ghz connection keeps disappearing and need to reboot route.r Any ideas?
27 REPLIES 27
Message 1 of 28
HI @jigsaw004
Perhaps your WiFi 6E card is only configured to use the 2.4GHz band, not the 5GHz. You can check this on your PC/Laptop by going to (assuming Windows 11):-
Settings > Network & Internet > WiFi > Hardware Properties > More Adapter Options > Edit
Then in the resultant box, click the Configure button, followed by the Advanced tab. What properties are listed here depends on your WiFi card's driver. Look in there for something like "802.11n/ac/ax" & see what it is set to, it might be disabled. If in doubt, please PM me a screenshot of the full list of properties available.
WiFi ModeWiFi Mode
Message 2 of 28
The problem seems to affect only the PC/laptop, other devices are fine. It cannot detect the 5GHz band despite being a WiFi 6E card. Is it running the latest drivers for it?
Do you have a USB WiFi 5 or 6 one that you can borrow?
Message 3 of 28
I am currently analysing the customer's diagnostic information.
Message 4 of 28
Hi @jigsaw004
Thanks for that zip file, I will get on the case a bit later this afternoon.
Message 5 of 28
Data as requested
Message 6 of 28
Hi @jigsaw004
Do not worry about interpreting the results; I will do that for you. I will send a PM to that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially, look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos, please, as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 7 of 28
Hello Keith
Thank you for offering your help.
I would love to see the guide, can you send it please.
Much appreciated
Message 8 of 28
Hi @jigsaw004
@Debbie-TalkTalk has asked me to help you. One other point is that the 5GHz band should be faster as the network adapters in your devices are designed to work faster in this band.
In other words, I will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Message 9 of 28
Hi @jigsaw004
Thanks for confirming this.
It does sound like WIFI interference.
Could you help please Keith? @KeithFrench
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 10 of 28
I was sent a WiFi Hub the same as I already had.
Fast 5464
Message 11 of 28
Message 12 of 28
I have installed the replacement router but it has made no difference
5Ghz is giving me speeds of 450Mps  whereas 2.4Ghz is only giving me speeds of about 35-40Mps if I am lucky.
These are speeds when next to the router.
I have moved router to different positions etc but has made no difference.
What can I try now?
Thank you
Message 13 of 28
Message 14 of 28
Thank you for the update
Message 15 of 28
Hi @jigsaw004
Thank you. I've ordered the replacement router, please allow 24-48hrs for this to arrive.
If you receive an email to advise that this is chargeable then please ignore this, I've sent the router free of charge.
Message 16 of 28
Account number has been added.
If you need anymore info please let me know
Message 17 of 28
Hi @jigsaw004
Please can you also add your TalkTalk account number to your Community Profile so I can locate your account details (please don't post this information on this thread)
Thanks again
Message 18 of 28
I have added the imfomation
Thank you
Message 19 of 28
Hi @jigsaw004
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
jigsaw004
Message 20 of 28
Yes please.  That would be great.
