on 24-03-2025 09:09 AM
Hello, two questions.
If I buy a seconds talktalk eero on eBay, will it continue to work? Would seem a great way of reducing ewaste.
Do talktalk sell new / refurbished euros and if so could you send me a price list?
on 24-03-2025 03:25 PM
Apologies Keith I must have skipped past and didn't see this -
The correct thing to do is to prove that you need an additional eero, by finding the root cause of the problem. I can help a lot with this
on 24-03-2025 12:58 PM
Hi @clivetunley
If you look at the thread that @Anonymous has directed you to, the only reason that customer has been offered an extra eero, is that my help was requested. My analysis proved that an additional was necessary. I have, of course, already offered you the same help.
24-03-2025 12:43 PM - edited 24-03-2025 12:46 PM
Have a look at this thread follow all instructions in it and you should get a second eero to try -
on 24-03-2025 10:16 AM
Thanks for the quick response. I'm trying to improve the WiFi connection in my (detached) garage so was just seeing what the cost would be. Happy to go to Amazon as I can return it if it doesn't work (eero or echo pop).
on 24-03-2025 09:16 AM
Hi @clivetunley
The correct thing to do is to prove that you need an additional eero, by finding the root cause of the problem. I can help a lot with this.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use.
The information below is provided by TalkTalk, for confirmation, please contact @Debbie-TalkTalk or @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
