Full fibre
Dazzler1976
Message 19 of 19
I have a question. I am upgrading from fibre 150 data only and copper phone line to full fibre 500 voip.   I am currently  using Eero 6 but told nit compatible with fibre 500 and I will be sent a WIFI Hub 3  postage at my cost.......
Googling has mixed reviews as always. Is the wifi Hub 3 bettwr to use or should yhis upgrade be given eero routers of a higher model I.e. 6 Pro or something?   And is the Hub 3 going to give me a good reliable connection  upstairs and extension back of house?
18 REPLIES 18
Message 1 of 19
Exactly  I will certainly repost the outcome  and or if any issues 🙏
Message 2 of 19
Probably not, most providers run on Openreach cabling in any event. Either way, the installation will take care of it.
benny55
Super Duper Contributor
Message 3 of 19
Is it a question of replacing the ONT or will it require an additional line into the premises?
Message 4 of 19
That's fair enough  wasn't sure.  I will make sure cupboard  is out to give them enough  space then. Much appreciated.
Message 5 of 19
If City Fibre installed the previous ONT then Openreach will replace it with one of their own.
GerryMac
Private Message TalkTalk PLUS
Message 6 of 19
Yes, hole drilled in front hall and cable run to ONT Box, from connection box outside where fibre cables are. Openreach carried the work out. Took a few hours.
Hope all goes well with the up-grade.
YNWA-JFT 97
Message 7 of 19
Thank you for reply.  Did open reach have to upgrade ONT box?  Apparently  they're coming as per usual assess area pull in cable drill into house for ONT.  We already have 1 which city fibre put in so unless needs upgrade  poss wasted visit.   Just need to know if my cupboard  needs moving.
Message 8 of 19
Hi @Dazz  I was using the Eero,s until I up-graded from FF150 to FF500 and was sent the Hub 3. Bit dubious in swapping over but I did and have no issues with it now. Had to contact the FF Team to get a few devices connected, but all sorted.. About 15 devices connected all over the house but haven't checked the signal in the garden as yet as it,s not warm enough yet to sit out, maybe next week as we usually get our summer then.. 🙄
HTH.
YNWA-JFT 97
Message 9 of 19
Yes will do. Think go live 9th June so fingers crossed.
Cheers everyone
Message 10 of 19
No worries. Let us know how it goes.  🙂
Message 11 of 19
Yea that's fair  enough.   If I have issues will need to get boosters from them.  If eeros don't work with the fibre 500 then  have no need for them I guess.
Thanks for help appreciated
Message 12 of 19
You can't connect your phone to an eero without a separate VoIP adapter. Which the  Hub 3 has built in. It is a decent and highly specced router, reserve judgment until you have it and try it out. The eeros should not need to be returned.
Message 13 of 19
Which fibre are you on. As they said must be hub3.   Do j have to send my 2 eero 6 back to them?    Does the eero 6 work even though they said doesn't?
Message 14 of 19
But atalktalk told me eero won't work with gibre 500 upgrade  and needed to be hub 3 🤷‍♂️
Message 15 of 19
@Dazzler1976
Bear in mind that as you are switching from copper to VoIP for your voice service that you will need the Hub 3 as it has a built-in socket to connect your phone.
Message 16 of 19
unfortunately each house is different. What may be better for one isn't the best for another.
I know some here who feel the hub 3 is better, personally the Eero suits my home better, especially as I have Echo Dots that work as extenders.
You can but try once your upgrade is completed to see which works best for you.
Dazzler1976
Message 17 of 19
Thank you for your time to reply.  Have you any experience  with the hub 3?  Does it have good range as always had issues reaching extension  rear if house and upstairs  bedrooms.
Many thanks
Gliwmaeden2
Message 18 of 19
Talktalk doesn't generally issue the Eero any more, @Dazzler1976, so the Hub 3 is their latest standard router.
