Full fibre
Dazzler1976
Message 32 of 32
I have a question. I am upgrading from fibre 150 data only and copper phone line to full fibre 500 voip.   I am currently  using Eero 6 but told nit compatible with fibre 500 and I will be sent a WIFI Hub 3  postage at my cost.......
Googling has mixed reviews as always. Is the wifi Hub 3 bettwr to use or should yhis upgrade be given eero routers of a higher model I.e. 6 Pro or something?   And is the Hub 3 going to give me a good reliable connection  upstairs and extension back of house?
31 REPLIES 31
Message 21 of 32
Hi @Dazz  I was using the Eero,s until I up-graded from FF150 to FF500 and was sent the Hub 3. Bit dubious in swapping over but I did and have no issues with it now. Had to contact the FF Team to get a few devices connected, but all sorted.. About 15 devices connected all over the house but haven't checked the signal in the garden as yet as it,s not warm enough yet to sit out, maybe next week as we usually get our summer then.. 🙄
HTH.
YNWA-JFT 97
Message 22 of 32
Yes will do. Think go live 9th June so fingers crossed.
Cheers everyone
Message 23 of 32
No worries. Let us know how it goes.  🙂
Message 24 of 32
Yea that's fair  enough.   If I have issues will need to get boosters from them.  If eeros don't work with the fibre 500 then  have no need for them I guess.
Thanks for help appreciated
Message 25 of 32
You can't connect your phone to an eero without a separate VoIP adapter. Which the  Hub 3 has built in. It is a decent and highly specced router, reserve judgment until you have it and try it out. The eeros should not need to be returned.
Message 26 of 32
Which fibre are you on. As they said must be hub3.   Do j have to send my 2 eero 6 back to them?    Does the eero 6 work even though they said doesn't?
Message 27 of 32
But atalktalk told me eero won't work with gibre 500 upgrade  and needed to be hub 3 🤷‍♂️
Message 28 of 32
@Dazzler1976
Bear in mind that as you are switching from copper to VoIP for your voice service that you will need the Hub 3 as it has a built-in socket to connect your phone.
Message 29 of 32
unfortunately each house is different. What may be better for one isn't the best for another.
I know some here who feel the hub 3 is better, personally the Eero suits my home better, especially as I have Echo Dots that work as extenders.
You can but try once your upgrade is completed to see which works best for you.
Dazzler1976
Message 30 of 32
Thank you for your time to reply.  Have you any experience  with the hub 3?  Does it have good range as always had issues reaching extension  rear if house and upstairs  bedrooms.
Many thanks
Gliwmaeden2
Message 31 of 32
Talktalk doesn't generally issue the Eero any more, @Dazzler1976, so the Hub 3 is their latest standard router.
