Full fibre
Dazzler1976
Message 26 of 26
I have a question. I am upgrading from fibre 150 data only and copper phone line to full fibre 500 voip.   I am currently  using Eero 6 but told nit compatible with fibre 500 and I will be sent a WIFI Hub 3  postage at my cost.......
Googling has mixed reviews as always. Is the wifi Hub 3 bettwr to use or should yhis upgrade be given eero routers of a higher model I.e. 6 Pro or something?   And is the Hub 3 going to give me a good reliable connection  upstairs and extension back of house?
25 REPLIES 25
Message 21 of 26
But atalktalk told me eero won't work with gibre 500 upgrade  and needed to be hub 3 🤷‍♂️
Message 22 of 26
@Dazzler1976
Bear in mind that as you are switching from copper to VoIP for your voice service that you will need the Hub 3 as it has a built-in socket to connect your phone.
Message 23 of 26
unfortunately each house is different. What may be better for one isn't the best for another.
I know some here who feel the hub 3 is better, personally the Eero suits my home better, especially as I have Echo Dots that work as extenders.
You can but try once your upgrade is completed to see which works best for you.
Dazzler1976
Message 24 of 26
Thank you for your time to reply.  Have you any experience  with the hub 3?  Does it have good range as always had issues reaching extension  rear if house and upstairs  bedrooms.
Many thanks
Gliwmaeden2
Message 25 of 26
Talktalk doesn't generally issue the Eero any more, @Dazzler1976, so the Hub 3 is their latest standard router.
