on 03-04-2024 10:05 AM
Hi I need some advice. Due to the way our house is set up we only get good BB signal in the living room and use the TP-Link Deco Mesh system for everywhere else. Currently on fibre 60 plan that s is being upgraded to FF 150. So I need to know if my Deco system will still work on this Eero 6 otherwise it'll be an expensive 1 room broadband contract. Not really tech savvy so keep it simple 😁 thanks!!
on 04-04-2024 03:25 PM
Yes you can continue using the current router with the deco mesh, speed should be fine
on 04-04-2024 03:15 PM
Do you mean continue using the current router instead of the eero? If so will it cope with the higher speeds ok?
Thanks 😊
on 04-04-2024 10:59 AM
OK thanks. I don't know if the deco mesh will work with the eero but if it doesn't your current router should work fine
on 04-04-2024 10:51 AM
Hi Chris I have the Sagemcom-FAST5464 currently
on 03-04-2024 10:17 AM
Hi Jackie,
Which router do you currently have?
