on 20-09-2023 12:47 AM
So my old router broke and had to put Eero 6 in. All fine and dandy for few hours...
What happens is wireless devices constantly disconnect or can't maintain connection. Think Alexa and smart home setup being completely useless because of it. Eero is up to date, so are wireless devices, its in my room, 13 devices total two of which are wired via 1Gbit switch. Both work completely fine.
Is there a way to salvage this apparently useless router or do I need to buy a proper router?
22-09-2023 10:31 AM - edited 22-09-2023 10:32 AM
No problems with TP-Link Archer AX12. Connected pretty much right off the bat, copied wireless details on it, unplugged eero, waited for wireless devices to switch over and ta-da! Everything works perfectly
So root cause was that eero router and its shining lack of functionality
on 21-09-2023 05:34 PM
You may face further problems with a 3rd party router unless it's used as an AP, if it doesn't connect using the wizard as a stand alone you may need to contact support, if it's a TPLink router the chances are it won't connect, the secret is vlan 0 (zero) in the router settings but TPL don't allow a vlan lower than 2.
Hope this saves you a lot of hair pulling & cussing, if this is the case message Chris he knows exactly how to sort it so it'll work.
on 20-09-2023 09:57 AM
Hi DYWinter
Thanks for letting us know.
on 20-09-2023 09:56 AM
This one can be closed. Ordered a proper router
on 20-09-2023 09:35 AM
Thanks but could you add either your TalkTalk landline telephone number or your account number to your community profile
on 20-09-2023 09:08 AM
Updated my deets. Well except alternative contact number as I don't have one
As for Eero. Ordered a real router from Amazon and replacing Eero with it, should arrive in the evening
on 20-09-2023 08:31 AM
Hi DYWinter,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
