Public IP Location
nevbull91
Message 7 of 7
hi All
Just upgraded to Fibre500 from 150 - changeover went ok. One very annoying issue I now have though is that the location of my allocated public IP address is not in my actual location - it's 40 odd miles away!
So sites like google maps that use public IP locations to work out my current location think I'm 40 miles away.
Talktalk support have no clue on how to fix it - operators on the chat have no clue what a public IP address is and if I call, I keep getting cut off of phone calls.
Has anyone else had this issue and a fix??? Or could someone from Talktalk support actually help me?
6 REPLIES 6
Message 1 of 7
The Edge router issuing your public IP address has changed.
I added a link to Google in my reply so that you can tell Google Maps your exact home location.
My public IP address currently tells me I'm 12 miles from where my home is.
Message 2 of 7
Thanks Gondola - interesting.  So why has it been fine for the 18 months I had fibre 150 and now it’s 40miles off?
Message 3 of 7
Your public IP address is issued by the TalkTalk Network Edge router which may well be located 40 miles from your home. Geo-location by public IP address does not identify your home location or the location of your router.
Google advice on how to Find & improve your location.
Message 4 of 7
hi Divsec - I have a wired setup - no WIFI.
Nev.
Divsec
Message 5 of 7
Hi @nevbull91 and apologies to @Anonymous for interfering, but this is how Google location works "Google uses a geolocation system called Wi-Fi location tracking to determine your location. This method is similar to using GPS, but instead of relying on satellites, it uses Wi-Fi networks and access points to pinpoint your location." According to Google.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
Message 6 of 7
I'm sorry to hear this. Can I just confirm, have you tried powering down the ONT for a full 30 minutes and then retested this again?
