on 18-12-2025 06:21 PM
Ive been through a few rounds of live chat and i've been told that i can keep the Eero 6 pro no problem but no one knows what i mean by this question.
How can I ensure this device is removed from TT Device Management systems so it does not get blocked /bricked in the future, please?
When I open the eero app it still says internet provided by TalkTalk and to contact TalkTalk for support.
There is still an admin user for TalkTalk customer support that i cannot remove.
I assume i need to supply the serial number somewhere for this to be removed
thanks!
on 19-12-2025 02:00 PM
Thanks @fr8ys.
on 19-12-2025 01:59 PM
Pleased they've done it for you.
They must have had a change of heart.
Might be worth resetting the router, or try the generic Eero app and temporarily disable the TalkTalk one.
on 19-12-2025 01:36 PM
Thank you for the update. It may take some time, but if it's not removed within 24 hours, please feel free to contact the number provided above if you have any further questions.
on 19-12-2025 01:22 PM
An update. My serial number was taken and i was told it has been removed from TalkTalk. I still see talktalk branding in the app but maybe that takes some time to filter through 😊
19-12-2025 07:11 AM - edited 19-12-2025 07:17 AM
Hi there Please contact the full fibre department so that they would be able to advise further on this for you:
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
WEB MESSAGING - Mon-Fri: 8am-9pm; Sat: 8am-7pm; Sun: 9am-7pm
Alternatively, you can use the below live chat link to live chat with them thanks:
https://community.talktalk.co.uk/t5/Articles/Our-live-chat-team/ta-p/2230529
on 18-12-2025 07:33 PM
I can't comment on the T&Cs, but as I've outlined is my understanding of the situation around the Eeros.
Support Staff will pick this up for you and be able to advise further.
on 18-12-2025 07:22 PM
Section 7 of the terms and conditions makes it sound like the router is yours to keep and use as you wish. It specifically mentions than that you will own the router not TalkTalk
on 18-12-2025 07:00 PM
No, the router is not yours to keep and use as you wish.
It is not unusual for equipment provided by ISPs to be locked to their networks.
People have issues with items bought from eBay and CeX that are locked, not necessarily TalkTalk ones, nor just routers.
on 18-12-2025 06:49 PM
If that is the case is this not an issue that can be brought to ofcom 😄
eero told me that forcing a hard reset a couple times can sometimes remove all the branding but there is still the issue that it may be blocked and turned into ewaste at some point
on 18-12-2025 06:29 PM
The original router provided is locked to TalkTalk. The only Eero that TalkTalk supply is one you have bought and paid for which can be used on other isp networks.
You may find it will work on another network initially, but sweeps are made locating Eeros that are not on TalkTalk networks and are then locked from use.
I don't believe that TalkTalk will unlock these Eeros or free them up if customers leave TalkTalk and require them to be returned and if not, charge customers for the non return
