Eero connection
gswainyboy
Message 4 of 4
Hi all. We have recently gone over to full fibre 150 and the eero router and a new tv box. It is all up and running fine with no issues. In the other room we still have a huawei youview box connected to our other tv. I cannot get this to connect to the eero router. Any ideas please.
3 REPLIES 3
Message 1 of 4
If it is the DN372T that only has an Ethernet & no Wi-Fi. How are you connecting this to WiFi?
Did you set the eero to the same network name & password as your old router?
Message 2 of 4
Hi Keith. I am using wi fi as the talk talk box is in a different room and the box connected ok with the old router.It is just that the Huawei box cannot see the eero router
Message 3 of 4
What is the problem, is that you do not have enough Ethernet ports on the eero? If so you need a gigabit Ethernet switch. This is an example, not a recommendation:-
https://www.amazon.co.uk/TP-Link-LS1005G-Wallmount-Ethernet-Splitter/dp/B07VWB347G/ref=sr_1_3?crid=3...
If that is not the issue, please can you explain it in more detail.
