on 03-02-2026 11:10 PM
Hi I`m on FF 900 (apparantly) what Cat ethernet do I need to connect 10 mtrs to my PC ?
Thanks ..
on 05-02-2026 07:03 AM
Hi there @fr8ys thanks for recommendation, @KmogReborn hopefully this will help.
on 05-02-2026 04:27 AM
Personally I'd go for the latest / highest cat to future proof.
Google is your friend here but there seems to be a large number of 10 metre cables around capable of handling your speed, but make sure you buy from a reputable source as there will be fakes around, i.e. lower rated cables marked as higher rated.
