FTTP + VOIP; Unable to dial out
kensevenoaks
Message 4 of 4
For some years I have used Fibre 150 together with GrandStream DVA and my analogue phone has worked fine. I now find I can't dial out.
Broadband Internet is fine, and I can use the TT digital app with some success, although voice quality is not perfect. It points to problem with the GrandStream DVA. I found the following advice from a previous posting. Is it safe to do this - I'm worried about deleting the settings on the DVA.
"plug the DVA (GrandStream) into the ONT, wait for the broadband light to come on then perform a pinhole reset of the DVA, this should get the phone light back on within about 5 mins, once that comes on can you change setup back to normal."
3 REPLIES 3
Message 1 of 4
Hi Ken,
If you experience any further problems just let us know
kensevenoaks
Message 2 of 4
Had a prompt and constructive reply from Michelle. Initial indications are that it might have resolved the problem but only time will tell.
Will update in a few day's time.
My TT contract is coming to it's end, the response has encouraged me to renew!
Message 3 of 4
Hi ken,
I'm sorry to hear this. Before trying to reset the DVA, have you also tried powering down the digital voice adapter for 30 minutes?
