Adding HP Deskjet to eero??
Skittywitty
Message 4 of 4
Hi does anyone know how I add my wireless Deskjet go to eero?
Cannot find it.. printer doesn't have display . Has WiFi light, obviously flashing at the mo, but cannot get it to be found either on its own app or through network.
Tried legacy mode and pausing 5g.
3 REPLIES 3
Message 1 of 4
I do have a workaround if the printer connects via WPS, but you will need an old router for this.
Chris-TalkTalk
Message 2 of 4
Hi Skittywitty,
Welcome to the Community. How are you getting on?
Message 3 of 4
Does the printer need to use WPS to connect to the router? If so, the Eero does not support WPS.
