FullFibre and no telephone
DGH39
Message 3 of 3
FullFibre connected by CityFibre early December, internet fine but telephone not working.  Numerous texts to TT but told everything OK. From looking online, seems as if I need a Digital Voice Adapter which was not mentioned by anyone I messaged.  TT online says can be got for free from BT/EE, but their plug in one only works for BT/EE lines.  How do I get one that works for TT and City Fibre?  I am totally frustrated.
Message 1 of 3
  • Name
  • Telephone number or Account number
  • Alternative contact number
Message 2 of 3
Hi @DGH39
Which router do you have, an eero or a WiFi Hub 2? I assume that you did apply for Digital Voice when you went for full fibre. So long as you did apply for it, then I can get TalkTalk to supply any missing items for you. If you have the Sagemcom WiFi Hub 2 though, all you need to do is to peel off the sticker on the rear of the router to reveal a phone port. Your phone simply connects to there & it should work right now.
