Guest network - no internet
jaybravo
Message 8 of 8
I set up a guest network to connect to an internet radio which I bought recently. The network has to be 2.4ghz as the radio is quite old. I eventually got it working. A couple of days later there is no internet on the guest network. The radio is connected but there is no traffic. My iPad says no internet when I connect to it. I’ve tried disabling then re-enabling the network, also rebooting the router but nothing helps. I have the black Sagecom router btw. The radio works fine via Ethernet
 Can someone help me getting the guest network running again?
7 REPLIES 7
Message 2 of 8
Thanks Thabile, do you have a link for the page where I can message them?
Message 3 of 8
@jaybravo  Thank you for your patience. I have briefly reviewed your account and noticed that you are on our full fibre package. We have a dedicated team for full fibre services. Please contact them at this number - Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
WEB MESSAGING - Mon-Fri: 8am-9pm; Sat: 8am-7pm; Sun: 9am-7pm
Message 4 of 8
Thanks for the info Keith 👍
Message 5 of 8
@KeithFrench thanks for the support.
Thabile-TT
Message 6 of 8
@jaybravo  Thank you for reaching out. I apologize for the network issue, I will need to review your account.
Message 7 of 8
There were some bugs in the router firmware that caused this. It does not affect everyone from memory. I am waiting to find out when the next firmware is released, so that I can check that it works now.
