How to solve problem of eero 6 not reaching all of house
cats6
Message 6 of 6
Due to the house being old the full fibre connection and eero6 are in the front bedroom but the best speaker in my kitchen cannot connect, how do I solve this?
5 REPLIES 5
Message 1 of 6
Thank you
Message 2 of 6
You should use an extra Eero of the same model to form a mesh network, that is how Eeros are supposed to work anyway. I am simply trying to save you some money.
cats6
Message 3 of 6
Sorry that's too much tech for me! The router and fibre input is in the bedroom at the front of the house  and the speaker is in the kitchen at the back. Do I need another router downstairs and if so would it be another eero 6? There is no fibre port downstairs.
cats6
Message 4 of 6
Message 5 of 6
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional Eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
