WiFi coverage after FTTP installed
SoF00
Message 15 of 15
Hi - We had Fibre150 installed last month and the new router position is no longer central resulting in the WiFi signal not reaching the far end of our house.  We have a couple of smart switches that require WiFi which are no longer working.
Is it possible to get one of the FAST266 mesh extenders to boost the signal ?
14 REPLIES 14
Message 1 of 15
Message 2 of 15
Thank you
Message 3 of 15
Hi SoF00,
I've ordered an eero and digital voice adapter, they should be with you within a couple of working days
Message 4 of 15
Yes please Debbie with the VOIP adapter, we'll give it a try.
SoF00
Message 5 of 15
Thanks DJI_MINI_2_SE 👍
Message 6 of 15
"Ah, ok.  So assuming the FAST266 is not available any more (to match my existing router) can I ask does the eero have better range"
How to set up eero router and beacons should you need them -
https://youtu.be/B1pv8bMfEtA?feature=shared&t=5
We have a single eero in the kitchen and at the far end of the house in the bedroom the signal and speeds are great.
Each eero device should cover an area of 190m2 or 1,500 ft2. However, this range is highly dependent on several factors, such as: Your home's building construction (older with thick walls, or new builds with foil-insultation)
SoF00
Message 7 of 15
Looks good (should have googled that myself).
Debbie - Can we try the eero with voice option then please
Message 8 of 15
"Also I have a bit of port forwarding setup (don't trust uPNP) can this be done on the eero as I have heard that it is less configurable than the WiFI Hub 2"
Port forwarding -
https://youtu.be/_7qsdcVE3uI?feature=shared&t=42
SoF00
Message 9 of 15
Ah, ok.  So assuming the FAST266 is not available any more (to match my existing router) can I ask does the eero have better range?
Also I have a bit of port forwarding setup (don't trust uPNP) can this be done on the eero as I have heard that it is less configurable than the WiFI Hub 2 ?
Message 10 of 15
@SoF00 wrote:
I didn't think the eero came with phone socket ?  We still need to use the old phone.
You can use your existing phone with the eero router, watch the video below  -
https://youtu.be/HyQRicd_bjY?feature=shared
Message 11 of 15
Message 12 of 15
Hi @SoF00
Thanks for your reply. It's giving me the option to order an eero, would you like to try this to see how the connection compares?
Message 13 of 15
Hi Debbie,  Yes it's the TalkTalk WiFi Hub 2 with the phone port. The software is at SG4K100206.
Message 14 of 15
Hi @SoF00
Can I just check, you have a WIFI hub and not an eero?
