Port Forwarding
njr1972
Message 26 of 26
I have Fibre65 and the Talk Talk Hub2 router.
I am trying to set up some port forwarding.
The routers interace, is not the greatest and its very slow. BUT I have to use this router as I have a VoIP landland.
All I want to do is a port forward as in the attached image, but its not letting me & its not telling me why.
Can anyone please advise ?
25 REPLIES 25
Message 21 of 26
The router is no more locked down than any other 5464. Have you tried a factory reset?
Message 22 of 26
Thanks very much for testing my rule.
This is the first port forward I have done, so there is nothing conflicting with it.
I will try to contact TalkTalk, as either my router is locked down or there is an issue.
Thanks for all the help
Message 23 of 26
I have just tested your rule on my 5464 & it not only was accepted, but it worked the first time. Have you created other rules that use the same ports for any other device or IP address?
njr1972
Message 24 of 26
Hi. Thanks for the reply.  It is actually a FAST 5464-1.T4 running SG4K100174 GUI version: 5.100.1.
THANK YOU
Message 25 of 26
I assume that this is the Sagemcom FAST 5364 & not the Hub 2 (FAST 5464)? If so what is the hardware revision of it?
