Problem Connecting to Fortinet VPN
DarrenW66
Message 39 of 39
Hi there, I've recently started experiencing connecting through Fortinet VPN from my home network (Talk Talk Fibre 65) when connecting through mobile data doesn't seem to have this problem.  is this a know problem from Talk Talk wifi and if so, are there any known solutions, please?
38 REPLIES 38
Message 1 of 39
Hi Darren,
I'm glad to hear this and thanks for the update.
Michelle 🙂
Message 2 of 39
A thanks to Keith and the various members of the TalkTalk team for helping to address this issue.  It seems to me that this issue has now been resolved - I know the network team were working on something to do with it, so I assume it has been that which has addressed the issue.  From my perspective, this thread can now be closed.  Best regards
Message 3 of 39
OK, I'll pass it over to our network team and ask them to take a look. I'll let you know when I receive an update or they may contact you directly
Message 4 of 39
Hi Chris, done that.  Still the same issue, unfortunately.
The first screenshot attached is using TalkTalk, the second is mobile data.  The TalkTalk connection does sometimes connect better, but then it soon drops to the poor connection again.
Thank you
Message 5 of 39
Hi Darren,
Could you switch the ONT and router off for 30 minutes, then switch back on and retest. If it's then still not working I'll pass it over to our Network Team for further investigation
Message 6 of 39
Thank you so much Keith.  I was thinking you might jump back in to help again:)
Best regards,
Message 7 of 39
Hi @DarrenW66
I have just tried pinging this same IP address & get the same result. I'll ask TalkTalk to get their networks team to deal with it.
Message 8 of 39
Hi Debbie, thank you for following this up.  Unfortunately the router hasn't helped.  In fact I've received some technical input from a friend and the check he led me through would appear to indicate that the route being used by TalkTalk for me to connect to the IP address in Singapore (which I am needing to have a good connection to) is not good.
I've attached a word document showing my connection to that IP address.  The first screenshot shows the data dropping when I use my TalkTalk connection, the second screenshot shows all the data going through when I use mobile data.  Hopefully TalkTalk will be able to offer a solution for this.
Regarding the router, I will get that sent back to you.  Are you concerned whether I send back the older one or the one you just sent me?  The only reason I ask that is I'm currently using the new router and if you are content for me to send back the older one, it will save me having to re-connect all those items around my house which are currently connected via that router.  Not a problem, though, for me to do that, if you prefer.  Thank you.
Message 9 of 39
Morning @DarrenW66
Hope you had a good weekend 🙂
How's the connection been with the new router?
Message 10 of 39
HI @DarrenW66
I'm glad to hear that the router has arrived.
I will check in again with you on Tuesday to see how you are getting on.
Message 11 of 39
Hi Debbie, thank you for the router.  I'll need a few days to assess properly whether it has improved things.  I'll be back in touch next week.
Best regards
Message 12 of 39
Hi DarrenW66
Thank you 🙂
Message 13 of 39
My apologies, I just added that now.
Thank you
Message 14 of 39
Hi DarrenW66
Please can you add your TalkTalk account number to your Community Profile, I can then send the replacement router for testing.
Message 15 of 39
Hi Michelle, yes please, let's give that a go.  I'll send it back if it doesn't help.
Thank you
Message 16 of 39
Hi Darren,
I'm sorry to hear this. Would you like us to send a replacement router for testing purposes to rule this out?
Message 17 of 39
Ah, OK, I guess I'm not then.  As I indicated, I wasn't sure.  My apologies
Message 18 of 39
It is just that your screenshot of the configuration you gave me, clearly shows that you are not using any certificates.
Message 19 of 39
Hi again Keith.  The Windows update hasn't helped, unfortunately.  Also, what appeared to be working by using the VPNBook connection is also no longer working.  I have to hot spot on my mobile phone data connection to get this to work at the moment.
Just coming back to your previous question(s):
'The Forticlient contacts the server and performs some encrypted exchange. Are you sure that you don't need to use any certificates? Did this ever work to your employer's VPN server?'
I'm at the limit of my technical expertise on this matter at this point.  However, I do believe certificates are used (I seem to recall something about certificates coming up occasionally when connecting the rdp).  And yes, this connection has previously been fine to my employer's server, it's just been the last 3 weeks or so when the problem seems to have arisen.
I realise that you're probably unable to help further on this, but I'm grateful for what you have done in getting things this far.  I don't know if the TalkTalk team are able to help any further?
Message 20 of 39
Morning Darren,
We'll check back in with you in a few days to see how you're getting on.
