Router
silverbird63
Super Duper Contributor
Message 42 of 42
I have a router that has a red light showing, it should be white. I have internet connection, but there is a fault with the router.
Have called and been sent the repeated message which dies not address it.
Please can you sort it.
Thank you
Not an expert at much just like to learn about as many things as I can
41 REPLIES 41
Message 21 of 42
Just kicking the tyres here but could it be this problem that is causing it -
There is a current faultly affecting some customers with Digital Voice (VoIP). The landlines are showing as not registered and in place of dial tone on the phone is a continuous tone like NU.
It is also causing a weird, quick light flashing between amber & white on the Sagemcom Wi-Fi Hub 2. When logged into the router, it shows the phone as not being registered.
On a Grandstream DVA, I would expect that the lights on it show that the phone is not registered either.
It is in hand with TalkTalk, please see the Service Status page for the latest information:-
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
Message 22 of 42
You are most welcome, I hope you enjoy the rest of your day. Thanks
silverbird63
Message 23 of 42
Message 24 of 42
Please note that as soon as you have a fault the first thing we need to do is run checks on your issue depending on whether its physically damaged or non-physical damage. As your services are working fine, I'm unable to run checks on this. Please monitor and if it gives problems, get in touch right away. Thanks
silverbird63
Message 25 of 42
Thank you for your assistance but I will be taking further action. My previous 18 months contract was a nightmare and now once again there is an issue. I will take this up with the retention team.
Message 26 of 42
I understand, please note that as your services are working fine you shouldn't have to worry about it. If it affects your services, you can get in touch and will have it looked into for you as soon as possible. This might be an issue connected with VoIP customers, really sorry about this and the inconvenience it's caused you. Thanks😇
silverbird63
Message 27 of 42
Yes. Why is the router showing red when the booklet informs me that there is a fault with the router.
Please send out a new Super Router and I will return the faulty one.
siphosethu-TT
Message 28 of 42
Great, is there anything you would like us to have looked into for you? Thanks
silverbird63
Message 29 of 42
We have the internet speeds as expected. There is no visible damage to the router.
Message 30 of 42
That's great thank you, please confirm if you having problems with slow speeds or the router having physical damage? Thanks
silverbird63
Message 31 of 42
I have done a speed test.
152 download
25 upload.
For your information I have not done a reset yet. Only unplugged for 10 seconds.
Message 32 of 42
No worries, I need you to check your internet as sometimes the lights won't affect your services. Thanks
silverbird63
Message 33 of 42
I have done that. The white light comes on but after approximately 30 seconds to a minute it then turns red.
Message 34 of 42
You didn't have to press the reset button but just unplug and wait for 10 seconds and the reset was going to happen automatically. Thanks
silverbird63
Message 35 of 42
How long do you hold the reset for please?
Message 36 of 42
Thank you, the red light typically indicates that there is a problem. Please try these few steps to help resolve the issue:
-Unplug the router from the power source, wait for about 10 seconds, and then plug it back in. This can sometimes reset any temporary issues.
- Ensure that all cables are securely connected to the router and that there are no visible damages.
- If the red light persists, you may need to perform a factory reset. This will restore the router to its original settings.
If you’ve tried these steps and the red light remains, please do let us know so we can support you further.
Thank you for your patience, and we’re here to ensure your router is functioning properly.
-Fez.
silverbird63
Message 37 of 42
Yes.
That is correct. We have full internet connection but the light is red.
Message 38 of 42
Thank you, just to make sure I understand, the router is showing red, but this does not affect your services, is that correct?
-Fez.
silverbird63
Message 39 of 42
Good Morning.
The issue is still ongoing.
The Router is still showing red.
angelique-TT
Message 40 of 42
Hi there, we're sorry to hear this. Please confirm if this issue is still happening?
