on 14-05-2023 03:56 PM
It appears that the engineers responsible for my FTTP installation saw fit to lay the cable around 10mm below the topsoil. Upon scarifying the surface in preparation for seeding, the scarifier proceeded to rip up the cable from beneath the surface, severing it and almost damaging my scarifier in the process (see attached images).
The sheer ineptitude of a fibre engineer deciding that 10mm is sufficiently deep for a comms cable aside ‐ how do I arrange for CityFibre to visit and rectify this problem?
on 16-05-2023 11:32 AM
Not entirely sure, @KeithFrench.
Wasn't on site, but when speaking to the engineer on the phone, they commented that the cable should have been buried at a minimum of 300mm, so I'll assume that's what they've done this time - don't really want to dig it up again just to confirm!
on 16-05-2023 11:03 AM
How deep did they bury the cable this time?
on 16-05-2023 06:42 AM
I'm really glad to hear this 🙂 I also received an update shortly after I left to advise that the engineers had resolved the cable issue and that everything was testing ok. I'm just sending you a short survey via a PM.
on 15-05-2023 06:33 PM
Evening, Michelle. Just an update to say that CityFibre visited this afternoon when I was at work, repaired and re-buried the cable.
I was not on site, but was assured that the cable has been buried to a minimum depth of 300mm and I can confirm that connection has been restored.
Much, much quicker turnaround than I was expecting. Many thanks.
on 15-05-2023 02:34 PM
Do we know when this engineer is visiting, Michelle? I'd ideally like the opportunity to dig a suitable trench for the cable so that it can be buried at a reasonably safe depth. I don't suspect the engineer will do this themselves, as it wasn't done the first time round - especially if they can get away with splicing the existing run.
on 15-05-2023 02:02 PM
I've now been advised that they will send an engineer to see if this can be fixed externally with no appointment and if they can't or need access they will let you know/make contact.
on 15-05-2023 01:20 PM
No problem, we'll check back in with you in 24hrs to see if you have been contacted.
on 15-05-2023 01:16 PM
Thanks, Michelle.
on 15-05-2023 01:10 PM
This has now been raised to CityFibre who will run some tests on the line and will contact you directly to arrange an engineer visit.
on 15-05-2023 12:16 PM
Thank you. We're currently looking into this and we'll post back as soon as we receive an update.
on 15-05-2023 11:35 AM
Thanks, Chris. Have actioned the private message.
on 15-05-2023 08:27 AM
Hi Swagatha_Christie,
I've sent you a PM to confirm some details so that we can look into this further
on 14-05-2023 09:46 PM
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
