on 14-10-2025 06:03 PM
Hi Everyone,
I'm seeking advice on the download slowness I've been experiencing since last Friday. I am on a Fibre 500 plan, and have FTTP. I would greatly appreciate your thoughts and help on this, please.
Before these issues began, I was generally seeing around 400Mbps on any given day, which I thought was acceptable. Since last Friday, I have been seeing very slow speeds; I am talking sub-1 1Mbps at peak times. I am seeing generally 200Mbps at non-peak times; however, I did check at 2am at night and saw 500Mbps. From 5pm onwards, the broadband is unusable.
Here's what I have tried so far, with little to no effect:
- Removing ONT and Router from the wall for 30 minutes + and going again.
- Factory resetting the ONT and Router.
- Had the ONT replaced by an OpenReach engineer.
- Changed ethernet cables.
- Tested a device directly connected to the ONT.
What other information I have at this stage:
- The speed definitely seems congestion-related based on timings.
- My next-door neighbour with BT as an ISP is receiving his quoted 600/600Mbps
- The OpenReach engineer believes this is not related to OpenReach fixable items.
My belief at the moment is that this is down to congestion/backhaul, but I am being given the run around by TalkTalk support.
Many thanks in advance
on 20-10-2025 01:50 PM
Thank you so much for updating us the issue has now been resolved @Decing.
on 19-10-2025 09:53 PM
For this threads reference - The issue was resolved by the OpenReach engineer at the exchange cabinet.
I am now getting consistent download speed throughout the day.
The explanation was:
"They have configured the line from the exchange to your premises and reset the settings to ensure the line is configured and synced with the server".
Unfortunately I don't know quite enough technically to comment on what this means exactly.
Interestingly I also received a TalkTalk email that you would normally see as a new customer "Your line is now online".
on 15-10-2025 08:41 AM
Thank you @KeithFrench for your help.
on 14-10-2025 10:42 PM
Anything on the FF network is a possibility.
on 14-10-2025 10:40 PM
Hi Keith,
The TalkTalk support agents have recommended an OpenReach engineer look at what's going on in the Exchange box. Do you anticipate that this could help this situation?
on 14-10-2025 10:33 PM
OK, the problem is with the full fibre network then.
The TalkTalk support staff on this forum do not have access to the Full Fibre systems. Therefore, you will need to contact the Full Fibre Helpdesk on: 0345 172 0074.
Their opening hours are Monday-Friday 09:00 to 19:00, Saturday 09:00 to 18:00, Sunday: Closed.
You may not always be able to speak to someone on this number; they may send you a text message instead. If that is the case, the text will contain a link to start an online chat. On that chat, you can insist on speaking to a person, but there may be a delay before you are connected.
on 14-10-2025 10:26 PM
Hi Keith,
Thanks for the message. When connecting directly to the ONT, I had almost identical download speeds, around 3Mbps download.
One thing I have forgotten to mention is that I have noticed that upload speeds seem largely unaffected by whatever is currently going on. I am hitting around 90Mbps upload speed at all times.
on 14-10-2025 10:23 PM
When you tested with a device directly connected to the ONT, what speeds did you get?
