Unable to make phone calls and interrupted dial tone but no voicemail message
chrishtie
Message 6 of 6
On Fibre 65 + VoIP. Over the past couple of weeks the dial tone has been interrupted but there's no voicemail message.
Last night we tried to make calls but none would connect - just get "unobtainable" tone
5 REPLIES 5
Message 1 of 6
Morning Chris,
How are you getting on?
Message 2 of 6
Hi Chris,
I'm glad to hear this. So just to confirm, if you dial 1571, it says you have no voicemail messages on the line?
Message 3 of 6
Hi Michelle
Thanks for the response.
Can confirm that it is the  WiFi Hub 2.
I've rebooted and it seems to have cured the problem of making calls but I still have the issue of interrupted dual tone but no voicemail message
Any advice would be helpful.
Message 4 of 6
Hi chrishtie,
I'm sorry to hear this. Can I just confirm, are you using the Wifi Hub 2? Have you tried rebooting the router and then retested this again?
Gliwmaeden2
Message 5 of 6
@chrishtie, try to reach Talktalk via Chat today.
Forum staff will be back on Monday
