Who do I contact to move my full fibre (FTTP) ONT?
stephen6pine
Message 11 of 11
10 REPLIES 10
Message 1 of 11
Hi there stephen6pine. The future fibre department will be able to advise further regarding this. https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
Message 2 of 11
I contacted the full-fibre team last Friday and an Openreach appointment was made for the 13 May. I was expecting an email that has not arrived. Are you saying this appointment was not made? The call lasted nearly an hour, I do not want to ring again!
Message 3 of 11
Thank you very much for doing so.
Looking into the notes on your account I can confirm that you will need to contact future fibre directly using the above number so that they would be able to look into this for you.
Alternatively you can use the below live chat link. Thanks
Message 4 of 11
Done.
I telephoned last Friday and an Openreach engineer appointment was made. I was told to expect an email, but nearly a week later and I have not heard anything!
nambuso-TT
Message 5 of 11
 Hi there stephen6pine. Could you please update your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
stephen6pine
Message 6 of 11
I contacted TalkTalk on 03451720074 last Friday, and after a long call an OpenReach appointment was made. But I was told I would get an email but none has arrived. How can I verify the status of the order without needing to ring?
Message 7 of 11
I do need to move the ONT, because a big home renovation means its current location will be behind a kitchen cabinet soon. But you did make me realise the router and ONT do not need to be the same room 😀
Message 8 of 11
Hi @stephen6pine
There might be another way, all depending on what you are trying to achieve. That is to buy a suitably long enough Cat 6 minimum Ethernet cable & run it from where the ONT is currently to wherever you want the router to be. I like to hide such a cable in some small white self-adhesive trunking.
amahle-TT
Message 9 of 11
Hi there @stephen6pine, you can also use the below details to contact full fibre.
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
WEB MESSAGING - Mon-Fri: 8am-9pm; Sat: 8am-7pm; Sun: 9am-7pm
Divsec
Message 10 of 11
Hi @stephen6pine probably the full fibre team, but your post has been escalated and you should hear tomorrow.
