Lag on PS5
Amir_Shahzad
Message 11 of 11
For the past 2 weeks I have been experiencing extreme lag spikes on my PS5 to the point it is unplayable, I have tried switching the bandwith from 5GHz to 2.4 but it only made it worse.
Any suggestions on what to do?
10 REPLIES 10
nomfezeko-TT
Message 1 of 11
Hello, @Amir_Shahzad thank you for reaching out to us regarding the lag spikes you're experiencing on your PS5. I understand how frustrating that can be, and I'm here to help you resolve this issue.
Here are a few suggestions you can try to improve your connection:
- If possible, try connecting your PS5 directly to your router using an Ethernet cable. This can provide a more stable connection compared to Wi-Fi.
- Ensure that your router is placed in a central location, away from walls and obstructions. This can help improve the Wi-Fi signal strength.
- Check if other devices on your network are using a lot of bandwidth (like streaming videos or large downloads). If so, try disconnecting them temporarily to see if it improves your PS5's performance.
- Access your router settings and consider changing the channel for your Wi-Fi network. Sometimes, interference from neighboring networks can cause lag.
- Make sure your router's firmware is up to date. Manufacturers often release updates that can improve performance and stability.
- Go to your PS5 settings and check for any network settings that may need adjustment. You can also try resetting your network settings on the console.
- If the problem persists, please chat back to us so we can check if there are any issues on our end or if your plan is sufficient for gaming.
If you've tried all these steps and are still experiencing issues, please let me know, and we can explore further options. Thank you for your patience, and I hope we can get this resolved for you soon.
-Fez.
DJI_MINI_3
Super Duper Contributor
Message 2 of 11
"Have you tried connecting with ethernet to see if that sorts it"
"That would be the last resort, but really an inconvenience as both my eeros are downstairs due to downstairs being bigger and my primary router was set up at the side of my house, not the middle"
I meant to see if it worked fine using ethernet i didn't mean to connect permanently using Ethernet.
Message 3 of 11
Hi @Amir_Shahzad any update?
Phili
Message 4 of 11
Yeah sure, sorry if I sounded rude btw didn't mean for it to come out like that, Ive placed my second eero upstairs and I know it takes sometime for the signal to start spreading so I will give an update in around 2-3 days.
Message 5 of 11
I know what you said. Give it a try?
Message 6 of 11
And as I said before my gateway eero is at the side of the house not the front, so I expected the other side to experience signal issues until we got another eero.
Message 7 of 11
Alright, I will try placing one of the downstairs ones upstairs, but the connection on the edges of the house downstairs may start to suffer, but as the PS5 is directly above the room that the main eero is in, I thought I would not experience these issues.
Message 8 of 11
Try experimenting with the placement of the eeros. I started with both of mine downstairs, but I now have my Gateway unit downstairs at the front of the house near the ONT and a second one upstairs on a window sill directly above. This works for me across the house as a  whole. Every set up is different, but a bit of trial and error can sometimes help.
Message 9 of 11
That would be the last resort, but really an inconvenience as both my eeros are downstairs due to downstairs being bigger and my primary router was set up at the side of my house, not the middle.
DJI_MINI_3
Message 10 of 11
Have you tried connecting with ethernet to see if that sorts it?
