eero router keeps dropping out
gp1090
Message 2 of 2
hi , i am having issue with Eero 6 router provided by talk talk, its keeps disconnecting itself and and speed keeps dropping , had use the old talktalk hub now , as the eero6 provided is not reliable at all. and even after reporting to fibre team , there is no help from there end, any help would be much appreciated
1 REPLY 1
Message 1 of 2
Hi @gp1090
When this happens is the problem that your devices disconnect from the Eero's wireless signal, or is the Eero disconnecting from the fibre ONT? Hopefully, the app will tell you that.
