eero6
pauline29
Message 4 of 4
Just a quick question If I set up the eero6 and decide I dont want it can I plug my modem back in which came with the fibre connection when I had it installed??
Thank You.
3 REPLIES 3
Message 1 of 4
There is a built in phone port on the back of the 5464. Remove the sticker, connect your phone there and your VoIP service should work. Alternatively, connecting an ethernet switch to your eero will not prevent your digital voice adapter from working. So you have two possible solutions.
Message 2 of 4
HI its TTs own wifi hub that came with full fibre  Fast 5464 2ta. Its only about 6mths old. Problem I have is eero dose not have enough ports as I have a phone to connect to. I have a digital adapter but my pc is hard wired to ethernet. I dont want to buy a switch if digital phone wont work.
Message 3 of 4
If you mean router rather than modem, then yes you should be able to. Which make/model is it?
