upgrade speed problems
on 18-02-2025 06:24 PM
Message 6 of 6
ive just upgraded to fibre500 and my download speed keep dropping speed
goes from 500meg then to 200 then 100 and 50 and 10 then back up slowly
then back down again.....
thanks craig
Labels:
- Labels:
Connection
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
5 REPLIES 5
on 19-02-2025 11:08 AM
Message 1 of 6
Hi craig,
Ok thanks for the update and please let us know if do you experience any drop in speeds.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-02-2025 11:06 AM
Message 2 of 6
hi michelle
yes am using a eero , ive turn off the eero for 20min looks like the speed is ok now...
i will keep a check on it.. and get back to u if any problem
thanks a lot
craig
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-02-2025 06:42 AM
Message 3 of 6
Hi craig,
Can I just confirm, are you using an eero? Have you tried powering down the eero and the ONT for 30 minutes and then re-tested the speed again?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
18-02-2025 10:36 PM - edited 19-02-2025 01:23 AM
Message 4 of 6
my pc dont use wifi wired only
thanks for the info....
craig
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-02-2025 10:22 PM
Message 5 of 6
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Back Again with a Internet Speed Problem in Full Fibre
- Speed Fluctuations in Full Fibre
- PC Running Slow - Wi-Fi Issue - Will Full Fibre Solve It? in Broadband
- Upgrade from 150mb to 900mb. No change in download speed only upload speed and go live date has gone in Full Fibre
- Fibre 65 lagging, discconections, slowing down, throttling? in Broadband
