on 31-08-2025 11:06 AM
It's a long time since I used 1471 .... someone rang in the early hours (at an inconsiderate hour) and I'd like to find out which number/who it was.
Tried ringing 1471 , but a message says "you are not subscribed to this service".
So ... what's going on here ??
01-09-2025 08:50 AM - edited 01-09-2025 04:00 PM
Hi @EssH88 Currently, the feature is set to be charged, which means it is turned off by default. If you choose to enable this feature, please note that there will be a fee of 20 pence each time you access it.
To activate this feature, you can easily do so through your MyAccount portal. Let me know if you are able to enable the feature on myaccount.
on 31-08-2025 05:44 PM
Voicemail. OK, never mind.
on 31-08-2025 05:12 PM
"A belated thought and forgive me if I'm wrong, but did you perhaps dial 1571? That would explain the "not subscribed" message. "
99% sure that I dialled 1471. I'm not even aware of 1571 (or what it's purpose is), so I wouldn't have dialled it (intentionally).
on 31-08-2025 01:43 PM
on 31-08-2025 01:11 PM
Hopefully the support team can clear this up. I tried it and it worked for me, I stopped short of pressing 3.
on 31-08-2025 12:57 PM
@ferguson maybe, but I thought there was now a charge, which is why you have to subscribe.
Hopefully someone will give a definitive answer, or maybe not???
on 31-08-2025 12:52 PM
I am not sure there is any charge unless you actually use the callback feature i.e. press 3? " ..... that's how I understood it too. However the wording (typically TT ) seems to be somewhat vague (maybe deliberately so ?) ......
on 31-08-2025 12:44 PM
on 31-08-2025 12:36 PM
It's charged for now so turned off by default.
It's 20p each time you access if you enable it.
You can add it via My Account.
Details here
on 31-08-2025 11:59 AM
Don't think I am using using VoIP .
on 31-08-2025 11:30 AM
Hi @EssH88 are you by any chance using VoIP? This might be the explanation.
