Home Phone
Ghost calls
rab107
Message 14 of 14
Since getting fibre, I have been getting ghost calls every 30 minutes. BT Advanced Z phone does not ring when getting these calls. I have hundreds of call logs, which is a pain when looking for genuine caller. I dialled 1471 and it shows no trace of these calls. I have reset my Hub 2 router countless times to no avail. When going into 192.168.1.1 all these calls show up as errors. I have called T.T. Helpline and they just do not understand.   Anyone know the solution? It would be much appreciated.
13 REPLIES 13
Message 1 of 14
Good afternoon,
I'm glad to hear this 🙂
Message 2 of 14
All Good Debbie Thank you
Message 3 of 14
Message 4 of 14
Hi @rab107
Can I just check, have you received any of these calls over the weekend?
Message 5 of 14
Thanks for the update. I'll speak to my colleague again as the fix we implemented yesterday morning should have resolved this. I'll keep you updated.
Message 6 of 14
Hi Michelle No Number calls stopped at 7.40 am on Tuesday but I got a no number call at 8.30 pm on Wednesday, when I dialled 1471 it was not registered so I presume it was coming from same source (pinging). I believe that virgin had the same problem when switching to fibre and solved it by adding a patch when updating router firmware. I also believe that when you make changes to my router for this problem,  you do not include the fix in firmware, so that when I need to reset my router for whatever reason the problem will return. This was told to me by a Talk Talk technician who is a friend of a friend. Kind  Regards  Robert
Message 7 of 14
Just checking back in to see if this has now been resolved for you?
Message 8 of 14
Hi @rab107
I made a change to a setting on the router. Hope this helps.
Message 9 of 14
Thank you. It would be good if you could mention what changes you have made
Message 10 of 14
Message 11 of 14
Thank you
Message 12 of 14
Hi @rab107
Apologies for this.
I've made some changes to resolve this issue. Please can you monitor the line over the next week and let us know how you get on.
Gliwmaeden2
Message 13 of 14
Staff will sort this when they reach your thread, @rab107 - probably Wednesday now.
It's a known issue.
