on 06-05-2025 10:18 AM
Is it possible to get list of incoming calls?
on 06-05-2025 10:24 AM
A very good morning to you @stormjai
Unfortunately, this would not be possible as we (TalkTalk) only keep a record of the calls you make from your TalkTalk landline to any number. The list of incoming calls would only be available on your particular device you are making calls from.
