Home Phone
Landline phone calls cut after 1 minute and I gat only engaged tone for several minutes...
frascofone
Message 3 of 3
As of two days ago, when I make calls from my landline the call goes dead after a few minutes. Than I get just an engaged signal when I try and redial. This lasts a few minutes an d then I get a dial tone again. The same thing continues so can only be on the phone for a couple of minutes. I can't use the phone therefore to report the issue, which is the way I would normally report a problem.
Thanks for any help.
siphosethu-TT
Message 1 of 3
Hi there frascofone, please confirm if you are still having the same issue so we can have it looked into. Thanks
Divsec
Message 2 of 3
Hi @frascofone your post has been escalated and you should hear soon.  In the meantime please check your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You could also go into "my account" and run the service checkers there.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
