Home Phone
Te joining talktalk
hosays299
Message 3 of 3
Hi I am hoping to re join you with broadband and home phone.
Would I still keep our number currently with Virgin media???
Message 1 of 3
@hosays299, read through the later part of this thread or similar on Virgin's own forum:
https://community.virginmedia.com/discussions/Telephone/porting-out-landline-number/5556351
Gliwmaeden2
Message 2 of 3
You need to check that Virgin tells Talktalk that you want to port the number across - they are on different types of infrastructure.
When it's done the other way around, Talktalk to Virgin, you are asked to tell Talktalk yourself. Check with Virgin to ascertain the system in reverse, @hosays299.
