on 01-04-2025 05:39 PM
Hi I am hoping to re join you with broadband and home phone.
Would I still keep our number currently with Virgin media???
Answered! Go to Solution.
on 01-05-2025 05:55 PM
Ok I be glad to not use them. As prices are so high now.
Will wait and see 👀
on 01-05-2025 05:18 PM
Up to you my friend, I am not a Virgin customer so have no direct experience of their customer services.
on 01-05-2025 05:17 PM
Would you say via chat or telephone??
on 01-05-2025 05:16 PM
It might be worth checking the position with Virgin at the very least. And if there are any issues, we can take it from there.
on 01-05-2025 05:10 PM
I have just re joined talktalk apparently.
Do I need to now tell vm or when I go live with tt??
on 01-04-2025 07:23 PM
@hosays299, read through the later part of this thread or similar on Virgin's own forum:
https://community.virginmedia.com/discussions/Telephone/porting-out-landline-number/5556351
on 01-04-2025 07:18 PM
You need to check that Virgin tells Talktalk that you want to port the number across - they are on different types of infrastructure.
When it's done the other way around, Talktalk to Virgin, you are asked to tell Talktalk yourself. Check with Virgin to ascertain the system in reverse, @hosays299.
