yesterday
Since moving to full fibre and receiving a digital voice adapter, my landline has not worked. I have reset many times. I have dis connected and re connected many times. All lights on the dva are full green.
yesterday
Can you try the following.
Resetting your Digital voice adapter
If your Digital Voice adapter or router has stopped working, we may ask you to reset it to check everything's working as intended. To do this:
Factory reset of the device will take a full 15 minutes and you need to wait until the allotted time has passed for the full factory reset to be completed. After 15 minutes, check your Digital Voice adapter device and try to re-test to check if the issue resolved.
yesterday
Yes I have tried 2 telephones on 2 different hubs.
yesterday
Hi Saus10,
Have you tried more than one telephone?
