Home Phone
No phone line but broadband okay
nick-stephens
Message 26 of 26
Hi. I have a problem with my phone line. The broadband works fine but I cannot make or receive calls. The handset works fine, however I get no dial tone, and attaching the handset to the test socket made no difference.
I really need the phone line to work so if you could sort it out soon, that would be very much appreciated.
25 REPLIES 25
Message 21 of 26
The two line tests that I've run have both passed, not picking up any issues but if your sure that the telephone is OK then we can arrange an engineer visit to investigate further. If you'd like us to do this please let me know and I'll confirm some details with you
Message 22 of 26
Also, my line test report is still showing a fault.
https://support.talktalk.co.uk/fault-timeline/REP-13321806
Message 23 of 26
It's a new handset which has been working up untl now. I don't have another one.
Message 24 of 26
Hi Nick,
Sorry to hear that you're experiencing problems with your service. Line test is passing, are you able to test with a different handset to make sure it isn't a problem with the phone?
nick-stephens
Message 25 of 26
I alkso did a line test. Reference number REP-13321806
