Home Phone
Phone line not working
olodart79
Message 5 of 5
Hi. I have a problem with my phone line. I can't make or receive calls. The handset works fine . there is a dial tone but there is no signal. I have checked my other handset and still the same problem. I have connected to master socket but made no difference.All the cables are fine.
I have done a line test but it says "Sorry, we had a problem checking your services"
Can any one help.I need my phone working ASAP please
4 REPLIES 4
Message 1 of 5
Hi Shayelol7#,
I'm really sorry to hear this. Please can you create your own topic and we can look into this straight away for you.
Shayelol7#
Message 2 of 5
My landline is not working properly. And has not been working for sometime now.  I have done the required checks but still no luck.  When I lift the receiver to make a call there is an engaged sound.  Both receivers have been checked no fault there.  I need this line open because of hospital appointments as I am undergoing treatment
Chris-TalkTalk
Message 3 of 5
Hi olodart79,
I'm sorry to hear that you are experiencing problems with your service.
Do you have our Future Fibre service?
Gliwmaeden2
Message 4 of 5
Add your Talktalk landline number to your community forum profile details for TT staff to identify your account, @olodart79.
Go via your avatar/name; settings; Personal Information. SAVE CHANGES.
Staff will use the information to check your line in the morning. Look for a response from them on here tomorrow.
