on 10-11-2025 03:27 PM
I have a landline with you and fibre broadband with you via city fibre. I am worried about losing my landline is it possible to port my landline number to a mobile phone.
Thanks for any help you can give me
on 11-11-2025 07:49 AM
You are most welcome.
Thanks for your help it is appreciated
on 11-11-2025 07:15 AM
Good morning @jstype I would suggest that you ask the mobile provider you want to port to if this is possible because we cannot port landline number to mobile, the only way to take your TalkTalk landline number to another provider is by doing a line take over that when you keep your landline number with another provider but not mobile.
on 10-11-2025 03:54 PM
I was thinking of RWG mobile. But I do not really mind as I would just get a cheap pay as you go sim and put the number on it. I was told via AI that EE and Vodafone will port the number and you would give the pac code. but Ai is not always reliable so thought I would check it myself with you as I do not want to accidentally lose the number
Thanks again
on 10-11-2025 03:48 PM
Hi @jstype Could you please confirm the mobile service provider to which you would like to port your landline number?
on 10-11-2025 03:42 PM
Thank you
on 10-11-2025 03:35 PM
Hi @jstype I will access your account and look into this for you.
