Home Phone
Porting landline number
jstype
Super Duper Contributor
Message 8 of 8
I have a landline with you and fibre broadband with you via city fibre. I am worried about losing my landline is it possible to port my landline number to a mobile phone.
Thanks for any help you can give me
7 REPLIES 7
Message 1 of 8
You are most welcome.
Phili
jstype
Message 2 of 8
Thanks for your help it is appreciated
Message 3 of 8
Good morning @jstype I would suggest that you ask the mobile provider you want to port to if this is possible because we cannot port landline number to mobile, the only way to take your TalkTalk landline number to another provider is by doing a line take over that when you keep your landline number with another provider but not mobile.
Phili
jstype
Message 4 of 8
I was thinking of RWG mobile. But I do not really mind as I would just get a cheap pay as you go sim and put the number on it.  I was told via AI that EE and Vodafone will port the number and you would give the pac code. but Ai is not always reliable so thought I would check it myself with you as I do not want to accidentally lose the number
Thanks again
Message 5 of 8
Hi @jstype Could you please confirm the mobile service provider to which you would like to port your landline number?
jstype
Message 6 of 8
Thank you
Mandisa-TT
Message 7 of 8
Hi @jstype I will access your account and look into this for you.
