Home Phone
Severe Crackling
EKG62
Message 30 of 30
I'm afraid I'm unable to hear anything on my landline phone due to severe crackling.  The phone is unusable.  I've had  something like this recently but it's much worse now.  Rain seems to make things worse.  My internet is also intermittent at times.  I've done the checks suggested elsewhere with no result.  The crackle starts as I pick the handset up even with a different handset.  The crackle is on incoming as well as outgoing calls.  I think it must be the external line.  Please help.
Internet user
29 REPLIES 29
Message 1 of 30
I'm really glad to hear that and thanks for confirming 🙂
EKG62
Message 2 of 30
Morning Michelle,  Many thanks for sorting this.  The line sounds very clear now.  All seems well.
Internet user
Message 3 of 30
We've received an update to advise that Openreach have resolved a fault on the line. I've re-run the line test again now which is also clear. How is the voice service, has the crackle/noise now been resolved?
Message 4 of 30
Thank you. The line test is now detecting a possible external line fault so I've raised this over to Openreach to complete an external line investigation first. We'll continue to monitor for updates and will post back as soon as we receive an update on this. No engineer visit to the property is required just yet.
EKG62
Message 5 of 30
New PM for you Debbie.  Apologies for my misunderstanding.
Internet user
EKG62
Message 6 of 30
Hopefully all OK now.  See PM.
Internet user
Message 7 of 30
Hi EKG62
I've replied to your PM. Once we have confirmed security then I can arrange the engineer visit.
EKG62
Message 8 of 30
I've replied to the PM.  Hopefully you have everything to progress with.
Internet user
Message 9 of 30
Hi EKG62
I'm just sending you another Private Message.
Message 10 of 30
Yes please Debbie.
Internet user
Message 11 of 30
Hi EKG62
Thanks for your reply. Would you like us to arrange the engineer visit?
EKG62
Message 12 of 30
Apologies - I had to go out.  Back now.
Yes - crackling with both phones and with or without the filter on the test socket.  Not sure how to test the router but internet connection seems OK although I did have some intermittent problem a few days ago.
Internet user
Message 13 of 30
Just checking back in to see how you're getting on?
Message 14 of 30
Thanks. Just to confirm, the crackling is present with both phones and with no other equipment, including the router connected to the line? Did you also try with and without the microfilter?
EKG62
Message 15 of 30
Thanks.  I've found the socket inside the NTE5 and plugged in.  I still have crackling on the line I'm afraid.
Internet user
Message 16 of 30
Thanks for confirming. An NTE5 should have a removable faceplate. I'd recommend removing the front plate very gently as there may be wires attached to the other side of the faceplate.
EKG62
Message 17 of 30
It's the NTE 5
Internet user
Message 18 of 30
Ok thanks. Could you have a look at the below Help Article and confirm which main socket you have please.
Your guide to main phone sockets - TalkTalk Help & Support
EKG62
Message 19 of 30
Thanks.  As far as I know there is just one socket that everything is plugged into.  Am I allowed to take the faceplate off to have a look inside?
Internet user
Message 20 of 30
Openreach maintain the line up to the test socket. Does your main socket have a test socket please?
